M491Cabriolet's Avatar
Need a bit of turn signals help
1972 911: Turn signals worked perfectly until out of the blue, they stopped working. The flashers work fine. I've been trying to figure this out over time and had gotten nowhere until today (see below). I looked into the turn signal switch behind the steering wheel, the flasher unit, the obvious wiring. No issues located.
Today, I tried checking current at the fuses. For example, left turn signal switch activated, car on, ground the check probe's wire and touch tip to either side of the fuse and the turn signals start working. Put the right signals on at the switch and nothing. Touch the tester probe to the right fuse and bingo, the turn signals work. I am the world's worst electrician, so I'm totally bewildered.
Can anyone help this electrical dummy understand what I'm seeing here? Thanks so much.
Old 08-24-2023, 07:10 AM
ROW '78 911 Targa
timmy2's Avatar
Corrosion at the fuses would be my guess. Moving them around even slightly cleaned them up enough to make good contact.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-24-2023, 07:19 AM
I did that too. It's interesting because I am touching the screws next to the two fuses, not the fuses themselves. I see a tiny spark on the screw when connection is made, and voila' the turn signals begin to flash. Same deal on both sides of the car. Front and rears flash properly.
Old 08-24-2023, 07:22 AM
M491
The way the turn signals work is that there is only one flasher for both the L and R blinkers. This single flasher has power to it with the key on, and sends blinking power to both the L and R blinkers all the time - but doesn't work until the circuit is grounded. The turn signal stalk completes the circuit by grounding either the L side blinker lights when pushed down, or completes the R side blinker lights when pushed up.
Again, the flasher unit sends blinking power to both sides all the time - it's only when one side is grounded through the turn signal stalk that one side will actually flash.
I'd take another look at your turn signal stalk wiring and see if adding an external ground there makes them flash. Could just be dirty contacts.
Now that I think about it, if both sides are not working, it's most likely not the switch. I'd check for ground going into the turn signal switch. The ground looks like it goes to the turn signals, headlights, door light switches, etc.... Check to see if something else isn't working - that may be a clue as to where to look for a bad ground.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 08-24-2023, 07:46 AM
66 911 #302694
Arctic Rat's Avatar
M491,
I'd start with changing out the flasher unit. Not expensive, easy to change and know if new one fixes the problem.
Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 08-24-2023, 10:08 AM
check to make sure the multi-pin round connector on the turn signal harness is fully seated.
Old 08-24-2023, 11:41 AM
PCA Member since 1988
IN addition to whatever else you are doing, use this opportunity to replace ALL the fuses. Over time, heat cycles, and humidity, the fuses age and crack, especially these olde open bullet style fuses. Sometimes you can't see the cracks until you remove them and the strips fall out. Throw the old ones away. You will save yourself troubleshooting headaches in the future. Do it every ten years.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-24-2023, 04:23 PM
Originally Posted by Walter_Middie View Post
M491
Great explanation on the system!
I am in the middle of replacing a tunnel, front trunk, front headlight, Left rear, right rear wire harnesses. The harnesses are in and checking power. My flasher isn’t working, but i do have a few grounds not connected. Checking these next
Old 10-03-2023, 07:39 AM
creaturecat's Avatar
ground it out. see what happens.
Old 10-03-2023, 08:53 AM
spoke's Avatar
Here's the turnsignal system for a '70-'73 914. The 911 is very similar. Note the fuse for the turnsignals. Likely you've burned a fuse if the 4-ways work but the turnsignals do not. I don't know what 911 fuse this would relate to but I'd check there first.
Don't replace the flasher as if it works for 4-ways it will work for turnsignals.
Find Spoke's LED Products:
www.spokeworksled.com
Old 10-03-2023, 11:52 PM
