-   -   1972 Steering Column Play - Will the 928 Part Work? (http://forums.pelicanparts.com/porsche-911-technical-forum/1147275-1972-steering-column-play-will-928-part-work.html)
Ryan_Cunningham 10-03-2023 04:56 PM
Noticed some play in the steering wheel the other day and went to research the fix. Removed the Momo wheel and there is significant play in the column in the vertical axis after tightening the shear bolts behind the dash. Probably 2mm of play which is certainly noticeable driving.
From the images and videos I’ve referenced I’m not sure that the steering shaft bearing below will work for my ‘72 as it only is listed to fit my ‘81 SC.
Anyone know if it’ll work?
http://forums.pelicanparts.com/uploa...1696377236.jpg
My steering column.
http://forums.pelicanparts.com/uploa...1696377270.jpg
Thank you for any assistance.
And a link to the video since I can’t determine how to embed YouTube videos.
https://youtube.com/shorts/0qsPxQ-eiMQ?si=wnfALXkTqp7Y455F
john walker's workshop 10-03-2023 09:35 PM
Different setup, won't work. Is the bearing cup and spring on the shaft?
HarryD 10-03-2023 11:45 PM
Different setup.
This thread can get you started. https://forums.pelicanparts.com/porsche-911-technical-forum/956638-help-1972-911-steering-wheel-bearing.html
You can order the parts though Pelican with these part numbers:
Spring: 914 347 713 00
Support: 695 347 725 00
Classic 911 10-04-2023 02:23 AM
Following
dg567 10-04-2023 05:32 AM
I had some play on my early car and the support 695 347 725 00 solved my issues.
Ryan_Cunningham 10-04-2023 10:12 AM
Thank you HarryD, spring and support ordered. My Haynes manual, which I haven't referenced since buying the Bentley for my 1981, has a good image of the steering column for the '72.
Will report back once the parts are installed!
Ryan_Cunningham 10-10-2023 07:21 AM
Apparently I’m also missing #27. Does anyone know what that part number is?
http://forums.pelicanparts.com/uploa...1696947671.jpg
dg567 10-10-2023 07:30 AM
Turn signal cancel - 90161332505
Ryan_Cunningham 10-10-2023 07:32 AM
Pelican should be paying you. Best service ever!
Ryan_Cunningham 10-12-2023 10:10 AM
DG567,
Night and day difference in the column! I also tightened the two bolts behind the gauges which seems to have helped as well. Thanks for a much improved ride to work this morning!
http://forums.pelicanparts.com/uploa...1697130616.jpg
tobluforu 10-13-2023 04:31 AM
More pics.
dg567 10-13-2023 05:04 AM
Originally Posted by Ryan_Cunningham (Post 12108131)
DG567,
Really makes a huge difference in the feel after you have all the right parts in there, right?! I had the spring in my column but was missing the bushing.
Sweet wide body!
Ryan_Cunningham 10-13-2023 09:30 AM
Originally Posted by tobluforu (Post 12108606)
More pics.
It’s a work in progress.
http://forums.pelicanparts.com/uploa...1697214535.jpg
http://forums.pelicanparts.com/uploa...1697214563.jpg
http://forums.pelicanparts.com/uploa...1697214605.jpg
http://forums.pelicanparts.com/uploa...1697214640.jpg
Ryan_Cunningham 10-13-2023 09:31 AM
Sweet wide body!
Huge difference!
