1972 Steering Column Play - Will the 928 Part Work?
Noticed some play in the steering wheel the other day and went to research the fix. Removed the Momo wheel and there is significant play in the column in the vertical axis after tightening the shear bolts behind the dash. Probably 2mm of play which is certainly noticeable driving.
From the images and videos I’ve referenced I’m not sure that the steering shaft bearing below will work for my ‘72 as it only is listed to fit my ‘81 SC. Anyone know if it’ll work? ![]() My steering column. ![]() Thank you for any assistance. And a link to the video since I can’t determine how to embed YouTube videos. https://youtube.com/shorts/0qsPxQ-eiMQ?si=wnfALXkTqp7Y455F
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C Last edited by Ryan_Cunningham; 10-03-2023 at 05:27 PM.. |
Different setup, won't work. Is the bearing cup and spring on the shaft?
Different setup.
This thread can get you started. https://forums.pelicanparts.com/porsche-911-technical-forum/956638-help-1972-911-steering-wheel-bearing.html You can order the parts though Pelican with these part numbers: Spring: 914 347 713 00 Support: 695 347 725 00
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-03-2023 at 11:56 PM.. |
Following
Sent from my iPhone using Tapatalk |
Titanium User
I had some play on my early car and the support 695 347 725 00 solved my issues.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Thank you HarryD, spring and support ordered. My Haynes manual, which I haven't referenced since buying the Bentley for my 1981, has a good image of the steering column for the '72.
Will report back once the parts are installed!
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
Apparently I’m also missing #27. Does anyone know what that part number is?
Titanium User
Turn signal cancel - 90161332505
Pelican should be paying you. Best service ever!
DG567,
Night and day difference in the column! I also tightened the two bolts behind the gauges which seems to have helped as well. Thanks for a much improved ride to work this morning!
More pics.
72 911 Although it is done at the moment, it will never be finished. |
Titanium User
Sweet wide body!
Huge difference!
