any 345/40 or 345/35 tyres in 16 inch ?
looking for available rubber for me and my friends 934 build.
10.5 fronts 12.5 rears. are there any available tyres in that size? i can find 17, but not 16... |
P7 Corsa are the largest 16s I have records for, 315/40 x16 and 255/50x16, kinda tall though unless there is a pretty torquey motor involved
I feared as much Bill
![]() any other options than these then... go for 17 maybe.. |
that's a drag radial and @27.7" tall going to be horrible unless you have 500hp +/-
in 17 Sumitomo HTRZ is 315/35 25.7" still a bit tall but useable w/ a decent 911 engine Nitto 555G2 same specs Nitto NTo1 315/35 x17 @25.34" is better but also a DoT R MPS@ 335/35 @526" is also little taller than desirable for most In 19 BBFG Rivals are 335/30x18 @25.9" etc The last 934 I looked at closely had the oe 10.5 & 12.5 x16 BBS centerlocks w/ Avon 13.5 /25.0
I have researched this to death a few years ago having a set of 10x16 CanAm wheels that I wanted to use for my M491 and/or a 934 build.
The available Pirelli Corsa's in 315/40R16 sidewall height is too tall. ![]()
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 10-15-2023 at 03:58 PM.. |
These wheels are 11 lb each IIRC, old 245 stretched over it here.
Tru6 Restoration & Design |
