3.2 Idle Speed Adjust Screw
Just a PSA. Was resetting base idle speed on the Carrera and as I was making the adjustment I heard a little wooshing/hissing coming from the idle speed screw area.
Wasn't sure if this sound was an actual air leak from atmosphere (e.g., false air) or just the sound of additional air inside the TB bypassing the screw. So I pulled the screw completely and thought I'd post some pics in case they'd help someone else: Idle Speed Screw: http://forums.pelicanparts.com/uploa...1696778971.jpg O-Ring dimensions: http://forums.pelicanparts.com/uploa...1696778971.jpg Since I already had it out I went ahead and replaced the o-ring w/a fresh one and reinstalled w/grease on it and the screw threads. HTH |
Thanks, Flat six
Yes thx, nice info
Has anyone found a replacement o ring?
I see kits online, just wondering if anyone has found a suitable replacement. Thanks- Erik |
And yes, thanks for posting this! Erik |
If you remove this to replace the o ring how hard is it to reset the idle correctly? Do you try to put it back in in as close to the same depth as possible?
I think some just count the revolutions upon removal to get it close and then go through the procedure of setting base idle. I have removed before (to inspect) and had no issues going through the reset procedure. Idle was high at first and corrected from there. 800rpm in my case. I ordered a set/variety of o rings for this from "the internet" so hopefully one comes close. |
Then rev the engine a few times and make sure it doesn't "hang" at a higher RPM than the setting. |
So Dave, would I just remove the idle speed screw, add the new o ring and put it back in fully seated, then start the car and drive around till its warmed up and then back it out till a steady 800 rpm?
Please be careful on the O-ring you use; it should be Viton or similar flurosilicone material, as hydrocarbons could eat away at EPDM or TPE/TPV "off the shelf" O-rings from hardware stores, etc.
Not exact specs so we shall see how they work. I just know the current o ring is shot. |
Nitrile is a "poor man's" Viton / FKM. Should be fine OK in this application, but it will now depend on how anal you want to be. Viton is best, though.
I will dive further down the rabbit hole as weather is keeping me from the yard and garage work :)
Thanks! |
Or...I'll just order a replacement for 10 bucks from our host! |
I have a large assortment of the "green" AC o rings...would that material work?
Those are likely HNBR (typically green color); very similar in performance to nitrile. Not as good as Viton / FKM, but probably OK here.
| All times are GMT -8. The time now is 08:52 AM. |
