Flat Six
Flat Six's Avatar
3.2 Idle Speed Adjust Screw
Just a PSA. Was resetting base idle speed on the Carrera and as I was making the adjustment I heard a little wooshing/hissing coming from the idle speed screw area.
Wasn't sure if this sound was an actual air leak from atmosphere (e.g., false air) or just the sound of additional air inside the TB bypassing the screw. So I pulled the screw completely and thought I'd post some pics in case they'd help someone else:
Idle Speed Screw:
O-Ring dimensions:
Since I already had it out I went ahead and replaced the o-ring w/a fresh one and reinstalled w/grease on it and the screw threads. HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 10-08-2023, 08:31 AM
Thanks, Flat six
Old 10-08-2023, 04:39 PM
Burnin' Rubber
Koizumi's Avatar
Yes thx, nice info
Old 10-08-2023, 09:30 PM
Gilles
RoW 88 Carrera coupé
Old 10-08-2023, 11:41 PM
fallingat120mph's Avatar
Has anyone found a replacement o ring?
I see kits online, just wondering if anyone has found a suitable replacement.
Thanks-
Erik
1986 911 Coupe
1986 911 Targa
Old 12-09-2023, 04:48 PM
Idle Speed Screw:
O-Ring dimensions:
And yes, thanks for posting this!
Erik
1986 911 Coupe
1986 911 Targa
Old 12-09-2023, 04:50 PM
If you remove this to replace the o ring how hard is it to reset the idle correctly? Do you try to put it back in in as close to the same depth as possible?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-12-2023, 10:57 AM
I think some just count the revolutions upon removal to get it close and then go through the procedure of setting base idle.
I have removed before (to inspect) and had no issues going through the reset procedure. Idle was high at first and corrected from there. 800rpm in my case.
I ordered a set/variety of o rings for this from "the internet" so hopefully one comes close.
1986 911 Coupe
1986 911 Targa
Old 12-12-2023, 11:11 AM
No need for a "procedure"! When fully warm, just turn the idle screw fully in, and back-out until idle is 800-825.
Then rev the engine a few times and make sure it doesn't "hang" at a higher RPM than the setting.
Dave
Old 12-12-2023, 11:32 AM
So Dave, would I just remove the idle speed screw, add the new o ring and put it back in fully seated, then start the car and drive around till its warmed up and then back it out till a steady 800 rpm?
Buck
'88 Coupe, '87 Cab,
Old 12-12-2023, 06:03 PM
Works every time.
Dave
Old 12-12-2023, 07:09 PM
Please be careful on the O-ring you use; it should be Viton or similar flurosilicone material, as hydrocarbons could eat away at EPDM or TPE/TPV "off the shelf" O-rings from hardware stores, etc.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 12-13-2023, 05:02 AM
The o rings I found are 'nitrile-butadiene' rubber...should be okay. (?)
Not exact specs so we shall see how they work. I just know the current o ring is shot.
1986 911 Coupe
1986 911 Targa
Old 12-13-2023, 09:28 AM
Nitrile is a "poor man's" Viton / FKM. Should be fine OK in this application, but it will now depend on how anal you want to be. Viton is best, though.
'07 Boxter
Old 12-13-2023, 09:35 AM
I will dive further down the rabbit hole as weather is keeping me from the yard and garage work
Thanks!
1986 911 Coupe
1986 911 Targa
Old 12-13-2023, 09:46 AM
Or...I'll just order a replacement for 10 bucks from our host!
1986 911 Coupe
1986 911 Targa
Old 12-13-2023, 09:47 AM
I have a large assortment of the "green" AC o rings...would that material work?
Buck
'88 Coupe, '87 Cab,
Old 12-13-2023, 11:21 AM
Those are likely HNBR (typically green color); very similar in performance to nitrile. Not as good as Viton / FKM, but probably OK here.
'07 Boxter
Old 12-13-2023, 11:50 AM
