Gas Fumes
Group, have an RS clone based on a 69 912 tub. Stock 3.2. Had some work done on the car including (or so I am told) new bottle under the dash, replace hard fuel lines, etc. Drove it back to Scottsdale from Rennsport yesterday, 11 hours and could almost not sit in the car due to the fuel fumes. I am told the last part of the system, the charcoal canister, still needs to be installed.
Would that solve this problem? I must say that this is a I need to get it done ASAP issue. Any thoughts are appreciated. I did not have this issue prior to the work being done
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
PCA Member since 1988
You need to get it done ASAP. I don't know if it's a fire hazard, but you don't want to find out the hard way.
The "bottle" (actually a rectangular box) up under the dash commonly cracks and leaks at this age, causing nauseating fumes, however you said that was already replaced. Yes, get the charcoal canister installed, or route the loose hose to the outside of the car and see if that gets the fumes out of your face.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I ran for a while with my 77 while doing other work with the washer tank and without the expansion tank hoses that were left open to the atmosphere under the fender. The fumes were present but certainly not overwhelming inside the cabin, just a little wafting could be detected at times.
Safety first: certainly make sure there no gasoline leaks underneath or engine compartment from the new replacement lines, also check if any holes in the filler neck, all/any clamps tight. Loose, worn gasket or no gas cap at all will cause overwhelming (raw gas) fumes. Likely the fumes are in trunk and entering the cabin. Not sure which tank you have but need to find the main evap hose line and have it exit out thru the fender until complete repair is made. A lot depends on what (vent) hose was removed and where they were left that’s drawing fumes from the trunk and into the cabin. |
New-ish 911SC Targa Owner
Does your car have heat? If yes proceed to the next question.
Does your intake setup ingest the crankcase ventilation gases that come out of the oil tank?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Have a look at the area around the fuel level sender.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Box in dash was replaced as were the fuel lines
Gas Fumes
As a test, cover up all of the holes in the frunk with tape, as others said, check or replace gas cap and check if there are any other hoses venting to atmosphere around the gas cap area. I put a 3.2 in my 72 and had similar issues until I replaced all of the hoses and now have the gas tank breather going to charcoal canister which has an exit hose going to exterior. No issue, even when filling tank to top
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
My SC had strong fuel smells. I replaced the washer/seal on the gas cap and no smells since. A cheap and easy thing to try.
This thread is informative as well. Fuel tank venting system question
FWIW, I recently had a strong smell of gas coming from the front of the car. It turned out to be a leaky fuel pump.
1984 Targa |
Not that this is important, but installing a new cork gasket on my fuel cap (which is under my hood) and a new sending unit gasket. Need to drive it some more, but I think these two fixes worked
