'87 carrera Evap canister full of fuel
Is this normal? Carefully disassembling front bumper assembly and noticed theres a bunch of liquid presumably fuel in the evap housing. Is this normal? or do i need to empty it.
Old 10-15-2023, 09:13 AM
1988 Carrera
shadowjack1's Avatar
I do believe that is your windshield washer reservoir.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 10-15-2023, 09:28 AM
That’s the washer fluid tank. Expansion tank is smaller, would be hidden behind the washer tank closer to the headlight (left side of your photo) if it’s there, I can’t see your expansion tank due to pic too dark.
Since it’s open and accessible it wouldnt hurt to clean out the washer tank, but most of the sludge and buildup will be in the washer hoses if the washer pump is still working.
Old 10-15-2023, 09:32 AM
lake wales fla
That is a vapor tank above the washer reservoir, the charcoal canister is in the right rear fender well. Raw fuel in the vapor (expansion) tank is caused by overfilling.
Richard
Update, i am infact someone suffering from LOW IQ. Upon opening the canister i was greeted with soapy window washer fluid. Its the window spray reservoir. My motor doesnt work so im deleting it. But yeah.
Old 10-15-2023, 09:34 AM
Oh wow just saw all the replies after making my update. Thanks to everyone who watched me embarrass myself.. haha hope you guys have a great sunday. Ope!
Bryan
Old 10-15-2023, 09:36 AM
PCA Member since 1988
We've all done it at some point...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-15-2023, 02:57 PM
Don't write the washer motor pump off too quickly. I took mine apart several years ago and it has just become a bit "crusty" inside from drying out and lack of use. Sprayed some intake cleaner in and rinsed it out and has been working fine ever since.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-16-2023, 09:15 AM
