Idle air bypass screw starting point
I deep cleaned my throttle body and removed all the parts while doing so. I didnt note how many turns to seated the air screw was. Is there a default starting point>
Old 07-02-2024, 10:20 AM
Flat Six
Flat Six's Avatar
IIRC, 3.5 turns out is a good starting guesstimate.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 07-02-2024, 02:33 PM
917_Langheck's Avatar
There are threads around this subject area, and the number I recall was between 2 and 3 full turns, mas o menos. I settled on 2.75 after cleaning the afm, resetting the afm sweep path, installing a new bypass screw, and a new O2 sensor. All vastly improved startup surging (original bypass was set at around 4.5 turns, so way lean), and off-idle bucking.
Old 07-02-2024, 09:53 PM
Are you asking a question about a hairdryer?
Please post the year and induction of your engine
Maybe even a pic of the part u r workin on
Old 07-03-2024, 01:22 AM
E Sully's Avatar
His garage shows a 1983 911.
Ed
1973.5 T
Old 07-03-2024, 03:33 AM
Flat Six
Flat Six's Avatar
My bad, I was assuming 3.2
Dale
Old 07-03-2024, 06:14 AM
