abides.
3.2 Ignition Coils NLA?
Anyone currently know of a source for new ignition coils for a 3.2? Pelican is showing unavailable for both the Genuine and Bosch options.
Graham 1984 Carrera Targa |
Edit: for some reason I thought it was distributor. A msd one should work fine.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic Last edited by Nditiz1; 10-17-2023 at 06:00 PM.. |
I have yet to find a coil with the proper voltages and designed to work on a 3.2 DME engine.
I had to find an old black coil from a salvage facility.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Burnin' Rubber
I agree with you. The new replacements are garbage and don’t work. I tried 2 different new ones over the past decade and they performed very poorly instantly.
Hope someone decides to make new ones correctly. |
ghttps://www.amazon.com/gp/product/B00029JLAY/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1#:~:text=to%20zoom%20in-,MSD%208222%20Blaster%20High%20Vibration%20Ignitio n%20Coil,-Brand%3A%20MSD
Got this from Amazon last spring.. 2000 miles later no issues |
O'reillys. Same coil, just gray top instead of brown.
Will this work?
https://www.ecstuning.com/b-bosch-parts/oem-bosch-ignition-coil-priced-each/94460211500~bos/ Looks like it is backordered too. |
Burnin' Rubber
Part number please? Or what coil does one ask for? I would love to have a good quality spare on hand for the day my nearly 40 year old used coil dies.
Dave |
Grappler
The 964 coils will work on a 3.2
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
I’ve been running an MSD Blaster High Vibration coil in my 85 for a couple of years with no problems. —Dave
1985 Carrera 3.2 • Prussian Blue Metallic |
Any insight about why they fail so much? I've read this for years now and I wonder what I'll do the day my 35-year old black original coil goes south.
Any good replacement to suggest?
Gilles RoW 88 Carrera coupé |
The best replacement coil for a 911 3.2 would be the 993 coil based on similar characteristics.
Dave |
For even earlier cars, in my case a 1970T, we find original "001"coils in working order and use them. Any of the aftermarket ones are suspect with relatively high failure rates. Oh, and I keep a spare in the frunk. ; )
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
May I ask what the N figure is your data? Transform ratio?
Correct, i.e. the turns ratio.
Dave |
I may order a 993 coil just to have it in stock and on my shelf for when I need it.
Can anyone definitively compare / contrast 964 vs 993 coils as potential substitutes for the 3.2 unit?
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
The Carrera coils were used across the models, 944, 928, and Carrera
Bruce |
