TSwede's Avatar
Good Grief.. I can't beleive the price...
... of a new ignition coil - nearly £100 with VAT and delivery for a '75 911s - there has to be a cheaper way - please advise - is this coil common to any other model of car? are there suitable aftermarket replacemets (pref avail in the UK)??
Certainly surprised me..
TSwede
Old 07-07-2003, 06:26 AM
emarsh's Avatar
My electronic ignition coil had developed a crack around the high tension tower and was arcing to the low voltage. I was going to replace it until I saw the price. At that point I did a repair job by cutting into the bakelite around the crack and filling it with epoxy. Its working so far.
1979 911 Targa
406ci Chevy powered '88 Fiero GT
Turbocharged 2000 Suzuki Hayabusa
1990 Buick Reatta
Old 07-07-2003, 06:29 AM
TerryBPP's Avatar
Use a MSD high vibration coil. they are 40 bucks for jegs.com. I have had mine for about six months and it works perfect.
Old 07-07-2003, 09:05 AM
I just popped in an Accel brand coil which works for cars from about 1970 to 1983. Cost was around $31.00. I had a thread a couple weeks ago titled "Inexpensive coil options" which has the Accel part number in it. You might search under "ignition coil" and you should find it.
Good luck - Jeff
Old 07-07-2003, 10:46 AM
TSwede's Avatar
Thanks all
Looking into these things right now
TSwede
Old 07-07-2003, 10:48 AM
304065's Avatar
And be sure to peel the silver sticker off the side of the MSD coil for that factory look.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-07-2003, 10:50 AM
TSwede's Avatar
re: ballast resistors
There was an earlier post about MSD coils (a blaster 2?) where someone asked if a ballast resistor was needed - but there was no reply - what is a balast resistor and are they needed with aftermarket coils?
TSwede
Old 07-07-2003, 10:53 AM
jphillips-998's Avatar
From my experience...LIMITED!...be careful in the coil you choose. Why? Well after one year, $2,000 at 3 very well respected shops trying to "tune" my MFI w/o success and nearly sending my MFI pump in for a rebuild as suggested my car finally died and was diagnosed as the coil. I was at a race track and bought a used Bosch coil for $50.00.
MFI problem solved.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 07-07-2003, 11:00 AM
