Oil filter console
Does anyone have a pictures on crankcase filter housing?
Iam interested how it looks and if adaptable to use on a street stock 3.0 1980 SC engine. |
It's a 914 ...
There's a thread that shows a few pics (though on an engine).
Help to ID this OEM Engine Cooler Blockoff You can also google the part number 930.107.205.1R or 930.107.057.01 |
N/A 993 or turbo 964/993 The turbo version is angled out a bit more, the n/a version hangs straight down Of course you lose the engine mounted fan and oil cooler when you install these We recently installed one on a n/a 964 case here's the link
filter console
The 993 console requires some creativity in air direction and blocking. Because this engine is convertible from my regular installation in my 73 with heat etc to my outlaw with headers and no heat. The 993 console needs a simple ALU panel to close off the cylinder and head at #6 and blocking oil cooler duct and associated sheet metal around that corner of the engine. And a thermostat plug. With the heater air nozzles gone, I’m not worried about some air leaking from gaps.
