Mystery Wires Under Dash 1981 SC
I just picked up a 1981 Targa light project which had an alpine stereo / amp hack install job back about a decade ago. I removed it all and figured out most of the wires but I have two pics of mystery wires under the dash.
In the first picture the location is right behind the radio. I think the brown with white stripe wire, circled with the blue highlighter I drew on the pic, goes to the (missing) glovebox door switch and the black wire with the red highlighted circle one I drew I have no idea what that is or the connector type. Never seen such a connector before.
In the second pic, the location is under the dash next to the passenger door footwell I have no idea what these cut and taped wires go or do (highlighted in purple).
Sean
Old 10-24-2023, 08:23 AM
Titanium User
Red circle is for a bulb - could be the ashtray light or the HVAC switch fan light
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 10-24-2023, 09:45 AM
Can’t see the colors of the wires in 2nd picture but if that’s solid Purple it could be + Right Rear speaker wire and Gray would be + Rt. Front probably part of the aftermarket set up they did any speakers with that still exist. Blue/Wht would amp remote switch. You say it was a hack job on the stereo so no telling where the - Neg. speaker wires are at.
Old 10-24-2023, 05:29 PM
Ok figured some of it out, thanks for everyones help. The brown with white strip is the glovebox light switch, the red circled one is supposed to have a bulb in it for the HVAC light and i'll check those right side wires tonight to see if they are audio ones.
Old 10-25-2023, 06:52 AM
