Cool Can I change my accelerator pedal?
1974 911S
In the process of swapping out my wooden floorboard for an aluminum one I noticed the base of my accelerator pedal was tearing. Looked up the replacement and noticed their is a later model that includes a tab on the bottom. It looks like that is there instead of having the accelerator stopper on the floorboard like the earlier version.
Do you know if I can save myself the hassle of adding the floorboard stopper to my aluminum floorboard by using this newer pedal?
Original version-
Later model-
Your thoughts are greatly appreciated.
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 11-06-2023, 02:13 PM
I would use the one requiring an installed stop. Just drill a hole, a 6mm bolt and 2 nuts. That way you can set it exactly. Otherwise the pedal with the tap may give you the correct distance or not.
Old 11-07-2023, 06:33 AM
Thanks, great idea. That is simpler solution than trying to remount the original stop on the new floorboard.
Rob Richardson
1974 911S
Turbo flares
Old 11-07-2023, 07:30 AM
