83 Targa
Porsche Crest Looking for wheel spacer guidance...'83 Targa
As the new owner of a 1983 Targa I am looking to fill out the rear wheel well a little with spacers. The existing tires are 225 x 16 on Fuchs 7. The front wheels are Fuchs 6 with 205 x 16 and I might space the a little too. Just curious as to whether 1" is too much on the back and open to suggestions to front spacers if any.
Also, i am not crazy about the bolt on spacers and would just get spacers requiring longer studs.......
Thanks.
Old 10-17-2012, 05:51 PM
racer's Avatar
1" is fine.. More will fit as well.
You should want some quality, hubcentric adaptors if going that large. Otherwise, you will need to replace the studs with longer ones too. The other issue with longer studs is, well, some are not threaded all the way down, so when you remove the spacer, you can't actually get the lug bolts to seat on the wheel. Also, with longer studs, you may need a super deep socket to install the lug bolts.
Good adaptors come with their own hardware for install.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-17-2012, 05:58 PM
83 Targa
Thanks for the information and help. I will look for spacers with new studs. Any suggestions for the front wheels? Anybody?
Old 10-18-2012, 04:11 AM
djcdmv's Avatar
here's a list with all available Fuchs sizes
it nicely shows the off-sets and backspacings, so it might be helpful
Originally Posted by Bill Verburg View Post
I made the chart using only factory wheel o/s w/o any spacers. But you only need to look at the width and o/s, either way. If a spacer is used it subtracts it's width from the o/s, since the net o/s is used in the chart add the width of any spacer used to get the native wheel o/s w/o a spacer.
Dave
Black 1985 911 Carrera M491
Old 10-18-2012, 08:42 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Post a pics of your rear & front wheel/tire/fender; one facing them and one at 45 degree as well as a side view of the car.
Who Will Live... Will See
Old 10-19-2012, 02:31 AM
OsoMoore's Avatar
I have late offset wheels on my 79 SC. Here is my info, including the spacers I ended up with.
My car is about 1/4 inch "off center". With the 2" spacers the driver's rear tire protrudes 0.5" outside the flare, while the passenger's side is exactly even. There is very slight rubbing on the driver's side which occurs when cornering to the right at high speed, or cornering right while going over bumps.
I am going to drop down to 1.5" spacers in the rear. That should move the driver's rear side to the position the passenger side is at now, which is safe.
Recap - With 964 (late offset, et52.3) 6+8x16 wheels I will be running 1" front and 1.5" rear spacers on my SC.
Front - 964.382.112.01 6Jx16-ET52.3 w/ P205/55/R16 89V tires
Rear - 964.362.116.01 8JX16-ET52.3 w/ P225/50/R16 91V tires
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 10-19-2012, 06:50 AM
nineball's Avatar
6&7/16 with a 23mm spacer on my 83.
no spacer
spacer
no spacer
spacer
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 10-19-2012, 03:43 PM
83 Targa
Thumbs up
Nineball....great visual and very helpful Where did you get your spacers? Did you get the bolt ons or ones requiring longer studs in a separate purchase?
Old 10-19-2012, 06:58 PM
nineball's Avatar
well, i bought a set of 23mm spacers on here and the seller shipped me 63-64mm spacers and basically told me to pound salt when i tried to return them. i ended up trading them for a set of h&r spacers a local friend had sitting on the shelf. mine bolt on with their own studs already there. i prefer this to the longer stud version, not based on anything scientific but just my own thoughts. it would seem there would be less stress on all of them in the end.
Old 10-19-2012, 07:06 PM
racer's Avatar
On the front its a bit harder since there is less room. You might find some small adapter (say 20mm or less) or you could run a 1/4" spacer. iirc, once you go beyond about 1/4", you run out of thread engagement for the lug nut.
Past:
Old 10-19-2012, 07:28 PM
RETIRED
Joe Bob's Avatar
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
2012 ML350 3.0 Turbo Diesel
Old 10-19-2012, 07:51 PM
I have 21mm H&R spacers on rear of 88 Carrera. Fills out nicely.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-20-2012, 05:02 AM
83 Targa
Ok so I ordered 25 mm spacers for the rear and will look at the front later. Thanks for all the good info and pictures.
I am driving my recently acquired first porsche in the form of an '83 guards red targa and can't seem to let it go slow? Its not my fault officer! Is that a common problem with 911's? Its just a fun car with a go-kart feel. It even has nice curves for waxing.
I want to clean the back side of my rear reflector lense.....how do I get that thing off? It has some darkening on the back side and I hope it only needs elbow grease.
Old 10-22-2012, 12:45 PM
Thinking of doing the H&R 28mm stud in spacers for my 81 SC in the rear. How about the front? What size spacer are people running on the front?
Old 11-12-2023, 03:11 PM
