930 bypass valve thats not open @ idle/low speed?
The C2 turbo bypass valve sucks unmetered air @ idle. Is there a good aftermarket valve that stays closed @ idle and low rpm unboosted cruise, and opens with higher vacuum on higher rpm closed throttle shifts? My '87 project.
Nobody home?
PCA Member since 1988
Probably no one else here has that car!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Slow old car
I don't know what the intake arrangement looks like, but can you set it up like modern audi/porsche/vw products that port the bypass into the intake after the air meter?
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
Can you put a check valve at the outlet? Won’t let the idle air in but will let the boost dump air out. I use one for an inverse problem where I let idle control air in but not boosted air out.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
