Brake light function
I want to wire in a new 3rd brake light does stepping on the brake send power to the black / yellow wire or does it connect the ground?
Thanks in advance joe |
PCA Member since 1988
Sends power to the brake light. The outside of the brake light socket is grounded.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 11-13-2023 at 09:39 PM.. |
Administrator
Yes, it appears to be the black/yellow wire. We have a pretty handy DIY article on installing a 3rd brake light which mentions where the best place is to splice one in. Hope this helps!
https://www.pelicanparts.com/techarticles/911_3rd_brake_light/911_3rd_brake_light.htm |
