Author of "101 Projects"
Wayne 962's Avatar
Pelican Parts WOW - Smokin' Deal on Mahle Nikasil Big Bore Cylinder Kits (2.5/2.9/3.5)
I just got a sale notice from one of our suppliers, offering some smoking deals on these piston & cylinder sets from Mahle. They appear to be clearing out their inventory. I bought mine last week from Andial for well over $3K, my cost!!! These are now offered at about $1000 off of retail. If you know what these are, then you know that these are smoking deals, and they will be good *only* while supplies last. Okay here they are:
2.7 liter to 2.9 liter 93mm Mahle Nikasil Piston/Cylinder Set, for CIS Injection, 9.2:1 Compression Ratio $2495 SALE (reg $3655)
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=PS93-001
2.5 liter 86mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.3:1 Compression Ratio, for 70.4mm crankshaft - 911 IMSA-GTU legal $2595 SALE, reg $3595
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS86-001
SMOKIN DEAL:
3.2 to 3.5 liter 100mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.5:1 Compression Ratio $2595 SALE, reg $3699
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS100-001
Again, I only have access to a few of these at these prices!
-Wayne
Old 06-13-2003, 01:24 PM
Wayne 962's Avatar
I also have these sets. Call Tom at 1-888-280-7799 (ONLY TOM) extension 221 if you wish to buy one of these:
PS98-007 3.0 to 3.2 liter (98 mm), 7.5:1 911 Turbo thru 77 $2695
PS100-005 3.3 to 3.5 liter (100 mm), 7.0:1 911 Turbo 78 thru 92 $2795
PS100-008 2.5 to 2.8 liter (100 mm) (Stroker Engines) 944 Turbo $1100
PS100-010 2.5 to 2.8 liter (100.5 mm),(Stroker Engines) 944 thru 88 $1100
PS102-001 3.6 to 3.8 liter , 102 mm bore/109 mm sleeve, (Machine In) 12.5:1 Carrera (993) 95-98 $2995
PS102-002 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 11.3:1 Carrera (964) thru 94 $2895
PS102-003 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 11.3:1 Carrera (964) thru 94 $2895
PS102-009 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 9:1 911 Turbo 93 thru 94 $2895
PS102-010 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 9:1 911 Turbo 93 thru 94 $2995
PS102-011 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 8.5:1 911 Turbo 93 thru 94 $2895
PS102-012 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 8.5:1 911 Turbo 93 thru 94 $2995
-Wayne
Old 06-13-2003, 01:45 PM
Bill Verburg's Avatar
Jump on these guys they are killer deals!!
Bill Verburg
Old 06-13-2003, 02:12 PM
BlGMlLL's Avatar
Send a message via AIM to BlGMlLL
What no 3.0 to 3.2 for my SC? I see how it is.
Old 06-13-2003, 08:54 PM
Reg Reg is offline
Reg's Avatar
Would that set of 2.5 P/C would be the ideal upgrade for my 2.2t?
I'd like to keep the original engine in my car but at the same time would love some more grunt. What else would I need to change in this engine?
1970 911 t (sold)
1985 MR2 (sold)
2011 GT 5.0
2007 CRV
Old 06-14-2003, 04:45 AM
Elombard's Avatar
Yah where is the 3.0 to 3.2 :-((( boo hoo
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-14-2003, 05:34 AM
Somewhere in the Midwest
MotoSook's Avatar
Same here Wayne..did you forget the 3.0 CIS guys? I don't know fi I could buy a set, but I sure would like to see the price. OR! Did you over look us because our 3.0 SC motors are so great they can't be improved upon?
Old 06-14-2003, 05:47 AM
Wow.. I never knew the plot was so frightening to some
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 06-14-2003, 08:56 AM
Schuey's Avatar
surely the 3.0 is fine as is...why ruin a good thing
1992 964 C4 Coupe (black/black)
1982 911SC Coupe (lt blue met/black)
1965 Mustang Fastback (black/black)
Old 06-14-2003, 11:38 AM
Wayne 962's Avatar
The 2.5 set is a good upgrade for the 2.2 engines. If memory serves me correctly, I don't think that you have to do any mods, although you just might have to cut the heads a bit wider for the wider cylinder, but I'm not sure...
-Wayne
Old 06-14-2003, 11:56 AM
Jeff Alton's Avatar
Can I run the 3.5s with motronic, or do I need MFI or carbs??
Jeff
www.turn3autosport.com
Old 06-14-2003, 04:44 PM
another glaring omisson- 3.2- 3.4 ltr. this is the best one if you
don,t want to bore the cases.
Keith Epperly- 87 slant nose cabriolet turbo look carrera
Old 06-15-2003, 07:12 AM
Forced Induction Junkie
WERK I's Avatar
Wayne,
I posted a question to you on the 3.0 turbo cylinders in the Engine Rebuilding forum. Thanx
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-15-2003, 11:22 AM
