Are Alternator fan shrouds interchangable from year to year?
I am in the middle of some upgrades on my 3.0l sc motor and found some cracks in the alternator fan shroud. I have located a couple but from 2.7 motors...will these work or not?
ian
Old 06-15-2003, 08:10 PM
304065's Avatar
what's the casting number? if the number is the same, they are interchangable, e.g. 0R vs 4R.
I have a carrera one and it's a 4R. It's not the same as an SC 0R and a hell of a lot different than the one from my 901. Also, depending on the year of your SC, the fan blade diameter was different, I think 78-79 were smaller, check Bruce Anderson's book.
keep cool!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-15-2003, 08:47 PM
Yep, fan size is the biggest differentiating factor.
Old 06-15-2003, 10:27 PM
304065's Avatar
The other critical dimension is the thickness of the mounting flange for the alternator. How I know this is I attempted to put a Carrera alternator in the 901 shroud, and when you mount the fan, it sticks out about 10mm from the front of the shroud, not good. Ach ja, so I then went to a 0R shroud, and the mounting flange is too thick, the bolts from the Carrera alternator don't stick all the way through. After machining that with a grinder for a couple hours, I threw up my hands and bought the 4R version. . . . just right. These shrouds can be expensive so it's best to buy exactly the right one.
'81 R65
Old 06-16-2003, 04:56 AM
thanks guys...that was exactly to info i was looking for...the one i found wont work.
ian
Old 06-16-2003, 06:20 AM
