turn signal flasher
So I just purchased a 1972 911T and when I turn on the ignition the turn signal indicator comes on and stays on. Both turn signals work fine and operate with the lever but the flashing indicator is always flashing regardless of the lever position. I have ordered a new relay but thought it might be the switch?
Old 11-26-2023, 01:32 PM
There is a Brake Light Warning Switch (USA only) that uses the flasher. If the car thinks your parking brake is on, you will hear the clicking of the flasher, and a light on the Tach should also flash. Try releasing the parking brake and see if the sound stops.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-27-2023, 03:40 PM
