2.7L Twinplug with 901/911 or 915
I am building a 2.7 Twinplug motor for the 71 911
Any recommendation for 901/911 vs 915 transmission. Pros and Cons of those 2 in the 2.7L? Can the 901/911 transmission handle the power of the 2.7? Why did Porsche goes with the 915 starting with 2.4L |
I'd go w/ the original 2.7 RS, Mg. case trans, 915/03 or /08, unless the rev range is drastically raised the /03 no cooler, the /08 a pump & cooler and slightly shorter 5 Alternately 915/44 If using a later Al. case the SC/RS or opt/SC/RS if track only
Following
Sent from my iPhone using Tapatalk |
Thanks Bill,
I already got the 915 915/68? I also have 911 transmission. Just deciding on which to use
It's a 914 ...
As Bill mentions, the 915 is a stouter trans, hence why Porsche started using it with the 2.4 in '72. A 901/911 will stand up to a 2.7 as long as you don't abuse it. The 915 is probably a better choice, especially if you already have one.
Your cable driven speedo will not work with that later 915/68.
Kind of Blue
What kind of power are you aiming for? A lot of people are pushing some serious power through 901s with no issue as long as you treat first and second with respect.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
gearhead
If you were considering a 911 mag versus a 915 mag with 7:31, like a 915/02 or 915/06, I would call it a wash. But that /68 is 3.2 Carrera with all the updates, 8:31, etc. and 108mm cv stub axles. You have it,use it.
Personally, like Mr bonus, I like the 911, because of the dogleg, and better shift pattern. The most common 2-3 up and down us in the same axis. You aren’t crossing gates to do it like on a 915. And with an aluminum side cover and bearing plate, it’s pretty solid for an adult driver.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
w/ the same tires and rev limit
here are the speeds in gear 915/08 '73 2.7RS 35 60 87 119 145 915/5/68 '84 US Carrera 3.2 40 71 100 126 159 the /68 is taller in every gear more suited for an engine w/ more torque SC/RS base 40 63 91 116 142 is closer to what you would want SC/RS option 40 58 79 100 126 is far sportier but might be unpleasant if a lot of freeway driving is in the cards
I guess on the 915/68 changing out R&P to 7:31 or 8:35 would make it better. And change out 5th to taller gear for highway.
Would that work? Quote:
gearhead
It would be substantially more expensive to change the final drive than to regear it to suit.
35 62 87 110 140 cruise rpm is getting uncomfortable 8/35 is just a tad raised from 7/31 35 63 88 111 141
If it's a 911/01 and using the same rev limit and tires as for the other trans I've posted here speeds in gears are 36 62 90 119 145 I'd use this trans if it's in decent condition
![]() ![]() So 911/01 it is. Will get it check out to make sure all is good. Should I go with stock flywheel or Patrick Motor Lightweight flywheel 8.5lbs vs 6.5lbs |
