3.2 Head Temperature Sensor curiosity
My '85 Coupe wouldn't start in cold weather (under 40F). I tested for spark - good. I could smell gas. I assumed the Idle Control Valve controlled air during start-up so I checked it - good. Then checked the Head Temperature Sensor (CHT) using the paperclip bypass method - - bingo, started right up. The CHT had already been changed with a 2-wire, but it looks like that failed as well.
Question - could someone explain what the CHT does to affect fuel/air mixture for cold starts. Knowing how to fix stuff is a lot more gratifying when I understand what it is I did. Thank you in advance! |
I probably misunderstand it, but since the CHT is a NTC sensor, substituting a short (paperclip or whatever) would trick the ECM into thinking the engine is warm, right?
So I wonder how that trick helped the OP with cold start under 40F ambient? |
Got it. Thanks!
Mine failed a couple years ago when I was 9 hours from home on the way back from Luft Indy. Luckily it was already warm, and I was able to ground the connector to the intake manifold and drive home without issue. (we ripped some horn wiring out of my buddy's 930 to make a jumper)
It did NOT want to cold start though. It took forever to get it started. |
Jumper both terminals together for cold start, and ground to intake to run/hot start. |
Cold start - momentarily (few seconds) remove jumper while cranking |
The issue still remains of why it flooded and did not start in the first place. |
When my sensor failed, it flooded and raw gas was emitting from the tail pipe.
| All times are GMT -8. The time now is 04:06 AM. |
