3.2 Head Temperature Sensor curiosity
My '85 Coupe wouldn't start in cold weather (under 40F). I tested for spark - good. I could smell gas. I assumed the Idle Control Valve controlled air during start-up so I checked it - good. Then checked the Head Temperature Sensor (CHT) using the paperclip bypass method - - bingo, started right up. The CHT had already been changed with a 2-wire, but it looks like that failed as well.
Question - could someone explain what the CHT does to affect fuel/air mixture for cold starts. Knowing how to fix stuff is a lot more gratifying when I understand what it is I did. Thank you in advance!
Dave Last edited by Another911; 12-04-2023 at 02:32 PM.. |
Chain fence eating turbo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Dave |
The OP later added the two wire sensor info after two posts.
Dave |
I probably misunderstand it, but since the CHT is a NTC sensor, substituting a short (paperclip or whatever) would trick the ECM into thinking the engine is warm, right?
So I wonder how that trick helped the OP with cold start under 40F ambient?
Gilles RoW 88 Carrera coupé |
The engine was most likely flooded even at 40F, so shorting the sensor allowed the engine to start sooner (leaned mixture).
Dave |
Got it. Thanks!
Mine failed a couple years ago when I was 9 hours from home on the way back from Luft Indy. Luckily it was already warm, and I was able to ground the connector to the intake manifold and drive home without issue. (we ripped some horn wiring out of my buddy's 930 to make a jumper)
It did NOT want to cold start though. It took forever to get it started.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Dave |
Jumper both terminals together for cold start, and ground to intake to run/hot start.
Cold start - momentarily (few seconds) remove jumper while cranking
Dave |
The issue still remains of why it flooded and did not start in the first place.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
When my sensor failed, it flooded and raw gas was emitting from the tail pipe.
Dave |
