-   -   1983 SC heater vent switch location? (http://forums.pelicanparts.com/porsche-911-technical-forum/1151764-1983-sc-heater-vent-switch-location.html)
ray40 12-07-2023 10:30 AM
Ive been trying to find the short in my starter solenoid wiring and understand that the A/c relay and the heater vent switch shares the circuit. can someone tell me where the heater ventilation switch is located? much tnx
Nditiz1 12-07-2023 11:07 AM
If you have the stock heater setup it will be right below the heater levers. I don't know the inner workings if you have the auto heat, but the base one makes contact when you pull the heat lever up. It pretty much grounds the fan in the engine bay at the ebrake lever.
ray40 12-07-2023 11:18 AM
Perfect thank you!
