1983 SC heater vent switch location?
Ive been trying to find the short in my starter solenoid wiring and understand that the A/c relay and the heater vent switch shares the circuit. can someone tell me where the heater ventilation switch is located? much tnx
Old 12-07-2023, 10:30 AM
If you have the stock heater setup it will be right below the heater levers. I don't know the inner workings if you have the auto heat, but the base one makes contact when you pull the heat lever up. It pretty much grounds the fan in the engine bay at the ebrake lever.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 12-07-2023, 11:07 AM
Perfect thank you!
Old 12-07-2023, 11:18 AM
