Would a loose Alt Belt cause my fuel pump fuse to fry on my 930?
So I was out driving today and could hear my belt squeaking so got home and parked it. About 15 mins. later I went to start it to move it into my garage and it would not start, thought
I had a hot start issue and then checked the fuses and the below pic is what I found. I moved some shims out to tighten the belt, replaced the 25 amp fuse and went for a drive, no squeak and it drove fine. Just wondering if for some reason with the alternator not spinning fast enough it would somehow cause this issue. Thanks for looking!
84 911 Cab 87 911 Targa 88 930 Cab M505 Slant Nose 62 356B Gone
PCA Member since 1988
I don't think your belt had anything to do with it. Two problems spring to my mind:
1. Cheap plastic fuse. Those should not melt. Get the genuine ceramic ones. 2. High resistance connection to the fuse block. Clean the metal spring where the fuse contacts, then bend it towards the other metal spring to make sure it clamps the fuse firmly in place. Long term solution: Get the Classic Retro fit replacement fuse blocks that use the plug-in fuses. There's another well-regarded supplier but I forget their name.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Northern Motorhead
What Pete says ...
I installed a retro fit blade fuse block in my 89 many years ago as i didn't trust the original fuses anymore which were coming loose and were a possible short waiting to happen. Lots of reading regarding the subject , most kits now also come with the updated headlight relays as well.
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Fuses get hot because the connections develop high resistance and the current causes heat to build up.
Yes, ceramic fuses have a much higher melting point than plastic ones, but the most important thing with any fuses is to keep the connections clean (free from oxidation). Modern fuses are less likely to develop contact oxidation. Anything drawing high current can cause the alternator belt to squeak, if it's not tightened correctly. I would check the current draw of the fuel pump to confirm if it's higher than normal. High current could indicate it's nearing end-of-life. |
It looks like the fuse did not blow. The element is still intact. As others have said, oxidized connections of the fuse to the holder will create resistance. Power dissipation is I x I x R. If resistance (R) is high, there will be power dissipation and heat generated. Clean your fuses and fuse holders with fine sandpaper and spray with contact cleaner to remove debris.
Find Spoke's LED Products: www.spokeworksled.com |
I noticed that the element was still intact as well which led me to believe that there was some corrosion and like you said resistance. Everything seemed to work today but am going to focus my attention to the fuse block and check them all.
Still curious to know the current being drawn by the fuel pump
If you look on Amazon, and search for ceramic bullet fuses, it will bring up several sets. Try and find one with copper contacts, and real ceramic cores. That is what your came with. The plastic replacements are junk. And I replace all the fuses every 10 years of so, and I clean the contact part of the fuse holder as well. Then coat the fuse with anti corrosion electrical compound.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Search term Flösser bullet fuse will get a result for a Texas supplier. |
