911 SC not starting clicking noise
Once a week or so, when I turn the key, I will get a clicking noise that seems to be coming from the dash passenger area. Usually, when the car starts, I believe it's like a loud buzzing noise and then it starts right up. If I hear the clicking noise instead, I know the car won't start.
Any idea what that could be? Thanks for your help! Porsche 1980 911 sc |
Sounds like a failed starter motor solenoid. My 1978SC is on its third solenoid in my 30 years' ownership.
Roy |
Battery? Just waiting for a cold snap. See if a jump cures your "clicking."
The clicking or buzzing noise you describe coming from the passenger dash area has me wondering if that's a seat belt warning buzzer. If it clicks instead of buzzes, that could be because the ignition switch isn't making good contact.
Check battery health first. Then see if you are getting full voltage to the yellow wire on the starter solenoid. If not, that indicates a poor connection in the ignition switch or starting circuit. |
Relay from lambda control unit? Sits under the passengers seat. Be aware: This relay is a special version with two 85 - correction - 87 outputs. Normally black and square housing, has an own socket. Feel in case manually by hand if this is the source of the noise.
Added the circuit diagrams: https://i.imgur.com/iHMTCSi.png https://i.imgur.com/goSCVua.png Otherwise a video would help a lot. Thomas |
More than likely you have arching on the starter solenoid contacts causing the issue of no start. Granted, this is just my opinion based on my experience with my 80 sc. |
Roy |
| All times are GMT -8. The time now is 09:12 PM. |
