911 SC not starting clicking noise
Once a week or so, when I turn the key, I will get a clicking noise that seems to be coming from the dash passenger area. Usually, when the car starts, I believe it's like a loud buzzing noise and then it starts right up. If I hear the clicking noise instead, I know the car won't start.
Any idea what that could be? Thanks for your help!
Porsche 1980 911 sc
Old 12-09-2023, 07:26 AM
Sounds like a failed starter motor solenoid. My 1978SC is on its third solenoid in my 30 years' ownership.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 12-09-2023, 08:07 AM
Battery? Just waiting for a cold snap. See if a jump cures your "clicking."
Old 12-09-2023, 05:16 PM
PCA Member since 1988
The clicking or buzzing noise you describe coming from the passenger dash area has me wondering if that's a seat belt warning buzzer. If it clicks instead of buzzes, that could be because the ignition switch isn't making good contact.
Check battery health first. Then see if you are getting full voltage to the yellow wire on the starter solenoid. If not, that indicates a poor connection in the ignition switch or starting circuit.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-09-2023, 06:23 PM
Schulisco's Avatar
Relay from lambda control unit? Sits under the passengers seat. Be aware: This relay is a special version with two 85 - correction - 87 outputs. Normally black and square housing, has an own socket. Feel in case manually by hand if this is the source of the noise.
Added the circuit diagrams:
Otherwise a video would help a lot.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-09-2023, 06:40 PM
Heck, I’m only 5 not 71!
targa80's Avatar
Originally Posted by Schulisco View Post
Relay from lambda control unit? Sits under the passengers seat. Be aware: This relay is a special version with two 85 outputs. Normally black and square housing, has an own socket. Feel in case manually by hand if this is the source of the noise.
Thomas
I looked at the 81 schematic and the oxy relay coil contact 66 (rd/wt) connects to fuel pump relay terminal 30. Terminal 30 is switched from normally open contact to closed on with terminal 87 when the fuel pump relay coil is energized by ignition switch power applied to terminal 87a. With terminals 87 to 30 closed and ignition switch in the start position power is supplied to starter solenoid and to the oxy sensor circuit. I doubt this is your problem but just disconnect the oxy relay and see if starter cranks over.
More than likely you have arching on the starter solenoid contacts causing the issue of no start. Granted, this is just my opinion based on my experience with my 80 sc.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 12-10-2023, 05:12 AM
You can check for this by shorting out the two big nuts on the solenoid. Use a screwdriver with an insulated handle and be prepared for some sparks. Remember that the the thick black cable to the starter is always live (with the battery connected). If the starter turns then it's most likely the solenoid. But the engine won't be turned because the solenoid has not levered the pinion into mesh.
Roy
Old 12-11-2023, 09:48 AM
