I used a tubeless bicycle valve, a piece of rubber fuel hose and some washers.
![]() Tightened to compress and expand the fuel line as a seal. ![]() Added zip ties for safety to keep the valves from launching. Precaution ![]() Pressurized with a bicycle pump. ![]() Everything is holding fine at 60 PSI. No bubbles.
78 SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8 HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 12-06-2023 at 04:29 PM.. |
Nice!
I think the oil pressure bypass valve trips ~85psig. You may want to increase your test pressure. |
ingenious. nice work.
Thanks for the compliments and recommendations!
Everything remained pressured at 60 PSI overnight. I have to get a better seal at the valves to dial the pressure above 85. At 85 I get an occasional bubble from the valve. Stay tuned.
78 SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8 HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
100 PSI and holding. 85 psi kept blowing out the plugs, so I added clamps and everything is holding strong. I really think the 60 PSI test pressure was adequate.
Thanks Shane! Just bought the same valves on Amazon yesterday. Can't wait to replicate your cheap tool.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Nick, I think a small piece of steel with holes drilled, or small cut outs, bolted in to clamp the valves using the cooler mounting holes would be of value. You could drill the holes to replace the big washers. Simply a steel plate with four holes. It would clamp better/tighter/safer.
And use the existing seals and bolts, gotcha. I think I have some steel, might even have some aluminum
Removed the suspect cooler from my car and tested. I really thought it was going to be the seals or something else but the cooler had a leak! I guess thats good news, my pressure test works. And I have a tested good, replacement cooler going in.
Heres what an air leak into water at 100 psi looks like.
