1987 911 front sway bar hardware
Hello today I discovered that the two rear bolts of my front sway bar brackets have backed out and are gone!
I have been searching for the spec on the bolts so I can sure up the suspension. Can you share the spec with me?
Old 12-09-2023, 03:32 PM
GG Allin's Avatar
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 12-10-2023, 10:30 AM
Ok. This shows the front bolt only. Maybe I’m to assume it’s the same for the rear one? The problem is it’s difficult to align the bolt and test the threads because of the bracket and the pressure needed on the arm. What I don’t want to do is strip the threads that go into the body. Can you confirm that this is the rear bolt as well? Thanks for the response!!
Old 12-11-2023, 06:58 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
If you take a look at the PET Diagram, you’ll notice that Find #11, 12 and most likely 13 has two entries each in the table. That’s the indicator that two each of the parts are required for the bracket.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 12-11-2023, 07:16 AM
They are both 8mm Bolts that use a 1.25 thread pitch. You can find these at any bolt supply place.
'82 911 SC
IG: @rywats
Old 12-11-2023, 09:04 AM
Thank you for the clarity. I have more confidence to crank those bolts!!😎
Old 12-11-2023, 04:14 PM
