pre-oiling a new turbo.
How much oil should I put down the top oil line on a new K27 before her first run. I have heard a few ccs to fill till it overflows. Probably not a big deal but I thought I would ask. I will probably go with the latter if not advised against it. Thanks again.
Pump it in until it comes out the drain line. But any is better than none.
I filled it till it came out of the drain line, and then did it again.
No problems so far |
I also pulled the fuel pump relays and cranked the motor for 30 secs a couple times
There are ignition delay timers made so you can run hard, stop, pull the key, and walk away while the car idles for a minute or so and circulates oil though the small restrictions in the turbo and prevents hot caking/clogging. Don't know if the 930 turbos are notorious for burning themselves out though.
| All times are GMT -8. The time now is 10:16 PM. |
