-   -   What to do to an SC while the drivetrain is out (http://forums.pelicanparts.com/porsche-911-technical-forum/1152394-what-do-sc-while-drivetrain-out.html)
Porchdog 12-19-2023 06:14 PM
1981 SC
I last had the motor and transmission out 28 years ago. Back then I did the clutch, had a shop do synchros and I resealed the easy areas of the motor. l have had a fun ride ever since.
I'm pretty sure my clutch fork is failing, so the motor and trans are coming out. While they are out I want to freshen the trans and add a LSD.
The motor also has some oil leaks I can address.
What else should I do while I'm in there?
This car will just be street use - probably no more AX or track events. Any recommendation for a street friendly LSD?
I know how I'm spending my winter....
Thanks Guys!
Bill Douglas 12-19-2023 06:26 PM
Put some SSIs on it.
Replace the sound pad.
sigchuck 12-19-2023 06:33 PM
Replace the vacuum line running to the tunnel for the brake booster and vent line for the evap. cannister. Those are relatively inexpensive and nice piece of mind even if they're not visibly cracked. I would also replace the tunnel lines if they're original. Len Cummings makes a great solution that's reasonable and it's a much easier job with the engine and trans outs.
fanaudical 12-19-2023 07:11 PM
It is (my opinion) much easier to replace the rear suspension bushings with the motor and transmission out. That might be something to look at.
Definitely check everything through the tunnel and address it while the motor is out.
A good engine bay cleaning can't hurt. Maybe check the seal rubber around the engine tin.
And check your ground straps.
rokemester 12-19-2023 07:12 PM
Great time to replace the rear wheel bearings, trailing arm bushings and other rear suspension bushings.
Matt at Pelican Parts 12-19-2023 07:45 PM
As far as the engine bay goes, it's a great time to clean any miscellaneous dirt/gunk out, plus check for corrosion, inspect the ground straps, and make sure every nut and bolt is tight that you have easy access to while you have all the free space.
PeteKz 12-19-2023 11:48 PM
THis^^. Especially the rear training arm bushings next to the front of the tranny. You must drop the trannny to get them out on most cars.
Porchdog 12-20-2023 03:51 AM
Fuel lines are new a couple years ago (Thanks Len!). Rear suspension bushings were done 25 years ago, but they groan when cold, so that's a good call.
SSi's have been on for years and I took out the evap canister decades ago...
Thanks!
rwest 12-20-2023 04:49 AM
Replace all of the gaskets, seals and hoses for the intake.
Adjust the valves.
Engine and transmission mounts.
Joe Bob 12-20-2023 09:43 PM
cvs
Porchdog 04-17-2024 05:24 PM
I finally got around to pulling the engine and trans.
As I suspected, the throw out fork was cracked.
Unfortunately, I also found a broken head stud. This job just got bigger and I have decisions to make.
al lkosmal 04-17-2024 05:47 PM
this
This really cleans up the engine compartment!
http://forums.pelicanparts.com/uploa...1713401121.jpg
REVerend 04-17-2024 05:53 PM
Please keep us informed on how things go… gonna drop the engine in mine one of these days and need to start making a list of stuff to do.
boyt911sc 04-17-2024 07:44 PM
Previous Attendee………
You had attended one of the Engine Rebuilding Workshops in the past. You had witnessed how easy to do the rebuild and replace those notorious Dilavar head studs. How many miles do you have now on the odometer? Refreshing those cylinder heads might be a good time to do them too.
Tony
Porchdog 04-18-2024 04:00 AM
Hi Tony,
Yes I did enjoy your class.
140,000 on the ODO - about 80K of those by me.
My plan was to wait until I retired in a couple years, build up a hotter motor (3.2 SS) , probably with ITB's and swap that in place of my original mill. (Al, I've been watching you!)
Now I need to decide if I just freshen this motor up per Tony, or use this as the base for the hot rod.
Thanks Guys!
