Fan pulley and fan blade ruined
I replaced the fan blade a few years ago and recently the alternator double pulley put 3shims inside and 3 shims outside the washer seated and everything looked good no belt squeaking. I had smog pump belt on seemed to need to be looser rather than tight to be quiet. Torqued pulley nut to specs. Started hearing a rattle in engine bay few months later I thought maybe the Smog belt was loose tightened . Still rattling felt the double pulley and realized it was not snug and removed to find both wiped out my pulley and fan blade mounting seating in the center. Any ideas LMK
Old 12-21-2023, 05:04 PM
post a pic.
Old 12-22-2023, 08:52 AM
Old 12-22-2023, 11:10 AM
Old 12-22-2023, 11:13 AM
Old 12-22-2023, 11:39 AM
I believe a new inner pulley can be installed on the fan
Old 12-22-2023, 11:44 AM
Looks like it can be repaired with a new hub.
Old 12-22-2023, 02:10 PM
That can be migged up and ground down to repair.
206 637 4071
Old 12-22-2023, 03:09 PM
A shim probaby got hung up on the grove and didnt allow it to tighten up properly
Old 12-22-2023, 03:19 PM
$119 don’t know if pelican sells them or not.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 12-23-2023, 07:34 AM
kgieg's Avatar
1+ for the mig weld and file/grind it repair!
A fair exchange is no robbery.
Old 12-24-2023, 08:11 PM
If you’re going to weld something like you want to tig weld it.
Old 12-26-2023, 04:52 AM
walt's Avatar
If that part is really $119 bucks I'd just replace it - no question.
Walt
82SC 3.0
81SC 3.6
Old 12-26-2023, 05:00 AM
It's a 914 ...
stownsen914's Avatar
OP mentioned a fan blade being damaged too. Give us a picture of the fan damage. It might be repairable.
Old 12-26-2023, 05:56 AM
I TIG those all the time both the hubs and the fan blades for customers.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-26-2023, 03:27 PM
356 guy
What technique is used to peen those rivets?
Old 12-27-2023, 03:07 PM
Alan L's Avatar
+1,
Pays to double check.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 12-27-2023, 03:32 PM
