-   -   mating a 67 trans to a 2.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/1153341-mating-67-trans-2-2-a.html)
inaminit 01-07-2024 07:37 AM
I am thinking about using a 2.2 engine in a 67. What are the clutch operation issues to be solved? Are the 901 trans splines and pilot bearing diameters compatible? I know that a 2.2 clutch is a push type with a cable that is different from later 915, so I would rather use the 901 cable that goes with the car.
Thanks in advance for your answers.
john walker's workshop 01-07-2024 08:47 AM
Use an early (69 and older) flywheel and clutch assembly on the 2.2.
inaminit 01-08-2024 03:03 AM
thank you John
