bose213's Avatar
Noise from rear window
Hello.
I hear cabin noise from the back like there is no rear window. I suppose it’s coming from the holes above the window. What is their purpose? Should there be any foam rubber behind these holes or something to block the noise?
Thanks.
Arthur.
Owns a Porsche 911sc 1979 Sportomatic.
Old 01-14-2024, 03:37 AM
Full Send Society
There is supposed to be open cell foam in that cavity to allow airflow out from the. Anon but even with foam it’s a major source of noise.
I filled mine and it was a very noticeable reduction in the sound when driving at speed. Then again, I have pop-out rear vent windows that allow air to escape when open.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 01-14-2024, 05:14 AM
You can also do the third brake light mod it blocks the vent pretty well https://forums.pelicanparts.com/porsche-911-technical-forum/1077624-theon-design-roof-vent-rear-brake-light.html
Old 01-14-2024, 05:55 AM
Full Send Society
That’s exactly what I did on my car and I think in that thread I explain how to do it without removing the window or headliner by fishing the wires in through the luggage hook hole. Wasn’t super easy but well worth it.
-Julian
Old 01-14-2024, 07:05 AM
bose213's Avatar
Got it. Thank you.
Arthur.
Old 01-14-2024, 10:00 AM
PCA Member since 1988
Duct tape.
I cover the vents when I know I'm doing a road trip, and in the winter. I'm sure there's a more elegant method, but this is quick and easy.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-14-2024, 08:54 PM
The vents are there for a reason. If the heaters or the AC blower are running at max, the air has to go somewhere. The factory put foam in there. From what I understand the only way to replace the old foam is the remove the headliner.
Not long ago I was driving west on I-40 with a legal speed limit of 75, but most cars moving at 80. There was a 50 MPH headwind, and my rear vents were howling. I had the heaters on, but only only on the first position of the blowers.
I thought about the third brake light LED options, and since it blocks the air flow, I did not order one. In the summer I run the AC and I want that air to move through the cabin to keep me cool.
Old 01-17-2024, 07:52 AM
I have enough other places where air gets in and out that I don't need to worry about blocking that vent.
From the last time I installed my new headliner, I'm pretty sure that you can just peel back the rear edge of the headliner and get access behind the vent to clean out deteriorated foam and install new. But that requires removing the rear window. If you have a sunroof, it may be possible to reach in there by unzipping the access seam.
Old 01-17-2024, 02:26 PM
