-   -   SC Throttle Linkage (http://forums.pelicanparts.com/porsche-911-technical-forum/1153857-sc-throttle-linkage.html)
booyah911 01-14-2024 01:55 PM
SC Throttle Linkage
Any suggestions how best to pop off the throttle linkage to the throttle body? I'm trying to remove the bell crank bracket on the engine and I can't get the link to pop off either end. Removing from the throttle body seemed easier but it's fighting me. This is an '82 SC.
Also:
(1) is this link NLA? I thought about dremeling it off but I don't see it for sale anywhere.
(2) the throttle body is wallowed out where the ball portion of the ball-socket connects to the throttle body (see pictures), creating more slop. Is there supposed to be a bush here or is this only fixable by repair/purchasing new throttle body?
Any help would be appreciated!
http://forums.pelicanparts.com/uploa...1705269082.jpg
http://forums.pelicanparts.com/uploa...1705269203.jpg
arbita1 01-24-2024 03:46 AM
It should pop off. I’ve taken mine off a few times from the bottom plate. I think I used a big flathead screwdriver.
Not sure about the slop you mention. I think that plate is all connected and shouldn’t affect anything. I can take a photo of my 83 for comparison.
rowingone 01-24-2024 05:28 AM
I think Stoddard has new ones year specific.
David Inc. 01-24-2024 05:42 AM
Jam a big screwdriver in there sideways and pry, it'll go.
It might have a little clip on it that prevents it from popping off, just a little bent wire around the opening for the ball. If you see that you'll have to take it off first.
mike sampsel 01-24-2024 06:50 AM
Screwdriver, or small open end wrench behind the ball to pop it off.
booyah911 01-24-2024 10:17 AM
Thanks guys. For some reason this post took days to publish. I was able to pop it off. I followed up with subsequent questions in another thread. Appreciate it!
