MFI injector cleaning
Who do you recommend for MFI injector cleaner and testing? Is this something I can do myself? 1972 911T
Aircooled Breakfast
I ended up buying one of these. Cleaning fluid is a combination of kerosene and ATF. Did a good job on an old set I had. I'm sure it's possible to build something similar for less.
https://mercedessource.com/store/bosch-mechanical-fuel-injector-mfi-tester-and-cleaning-kit |
Good suggestion . . I have watched his videos. I just emailed Pacific Fuel injection to see what they would charge for clean and test.
Aircooled Breakfast
I'm just up the road from you in Cheyenne. I'd be glad to clean and check them if that would be helpful.
John |
Well that's nice of you John! I appreciate the offer and I will let you know soon.
Search eBay for Diesel injector pop tester. Direct copy of the Bosch tester for about $100, or you can make your own from a bottle jack.
injector cleaning
It's a 914 ...
I believe the pump rebuilders like Pacific and Mark Jung offer an injector testing service.
Everyone that maybe used to clean and test the mechanical injectors doesn't do it anymore. You can clean them by backflushing the injector to clean that little screen but if the spring is not up to the task . . it won't matter if its clean or not. Just not happy to pay $125 a piece but that might be the best solution.
Injector Masters in Oregon says they will clean and test crack pressures and flow volume for $25 each . . he says he has good results with the MFI injectors.
I think I will get one like this for $90 shipped and put a 100 psi gauge on for my CIS injectors. Then I can better check for opening pressure, leaks and spray patterns. The 73.5 injectors are unique and very expensive, about $250 each. I've acquired 22 used ones and this should help me sort them out. ![]() I've played with some of them to back flush the internal screens ![]()
Ed 1973.5 T |
I converted my Diesel nozzle tester to MFI. Gus at Pacific FI gave me the name of a gauge company. Liquid gauge is locked at MFI injector opening pressure. Tool can be locked to flush and opened to check pressure.
![]() ![]() Last edited by gled49; 01-28-2024 at 06:38 AM.. |
CIS needs a lot less pressure, I'll just change it to a 100psi gauge.
Ed 1973.5 T |
Coram Deo
I believe Jonny042 had a similar experience. Are these pop injector testers any different?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
If you watch the video for the one in post 2, it seems they had to update their pump due to contamination issues. He addresses that in the video here,
https://youtu.be/wOuJna_wRv4?si=OQRfTQdlwComKFAo I ordered from a different company, all reviews were positive. Mine arrived an hour ago, and unfortunately UPS was not exactly gentle. They managed to snap the threads off the gauge. Going to be hard to do anything, claim filed with UPS and sender notified. Besides not having a gauge, it seems very solid. The one mentioned in the video shows how they started adding a filter. The one I have has an integrated filter for the fluid. ![]()
Ed 1973.5 T |
I had an idea to use a pressurized injector cleaner with solution like this from Amazon. If I hook this up with the appropriate pressure at the MFI pump fuel inlet why wouldn't this be an effective way of cleaning both the pump and the injectors? It won't backflush but seemingly would require little labor. They also make some injector cleaner that will support combustion, designed to run through a running engine. Thoughts?
https://www.amazon.com/dp/B09KNNSDFH/ref=vp_d_vp_d_fuw_pd_pd?_encoding=UTF8&pf_rd_p=f20fcda8-2440-4bfe-9c09-83295cb4a15a&pf_rd_r=NN02FN1MWQCSFVSV2P47&pd_rd_wg=jlwOC&pd_rd_i=B09KNNSDFH&pd_rd_w=iqw2E&content-id=amzn1.sym.f20fcda8-2440-4bfe-9c09-83295cb4a15a&pd_rd_r=4d91eca6-fbda-4805-a040-4d64954fa3f9&psc=1 |
It's a 914 ...
The trick would be to get enough pressure to crack an MFI injector. That system mentions 140 psi, I think that's not enough.
Functionista
The only thing that back-flushing won’t clean is rust particles, which are more common than you might think.
Also, DM me and I will check/clean them for free with a Bosch tester as I’m right down the road…
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Functionista
I use slightly diluted Naval jelly type products to dissolve rust at filter side, does a good job,
What I was trying to avoid was removing all the injectors from the car. After soaking in penetrating oil over two days they still seem too tight to remove easily. The needed pressure to open the injectors would be provided by the MFI pump if I add the cleaner at the MFI pump fuel inlet. Thanks Jeff for the generous offer . . I will let you know should I decide to remove the injectors.
