Where to get a replacement Tachometer for 84 911?
The tachometer in my 84 911 Targa isnt working properly.
I sent it to Nichols Speedometer & Instrument (NSI) for repair but they were not able to fix it.
So is there a reputable source for a replacement tachometer?
A good used one would be fine with me.
TIA
Old 01-11-2023, 08:12 AM
esample's Avatar
I have one from an ‘86. Works perfectly but I don’t know if it will work on your car.
-e
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 01-11-2023, 08:32 AM
Slow old car
I’ve got one for a 1980 sitting in a box I’d sell you, but like esample I don’t know if that’s the right one for your car.
Hookups are + - and TD (low voltage square wave signal)
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 01-11-2023, 09:17 AM
7783911's Avatar
Try JBELL on this forum
Old 01-11-2023, 09:26 AM
Send it to someone like Palo Alto and have them add a voltage meter to it, and repair the tach. Score!
I love having my voltage meter right in front of my face.
Old 01-11-2023, 02:30 PM
PCA Member since 1988
I had John Bell do mine. Put a voltmeter in the bottom of the tach, just like Glen's above. Love it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-12-2023, 10:48 AM
Grappler
Rodsrsr's Avatar
Plus one for JBell. He does fantastic work.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-12-2023, 11:08 AM
I'm in the same postion as you guys, I dont know what other years would fit the 84.
I think the 86 since its a 3.2would, but not the 80.
Do you guys mean jbell959 ?
thanks
Old 01-13-2023, 10:36 AM
Slow old car
yeah, Jbell959 is right. he's gonna be your guy for this
Mike
Old 01-13-2023, 10:58 AM
Kind of Blue
MrBonus's Avatar
Another vote for John Bell as he does amazing work and, as others have mentioned, can modify it nicely if desired.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 01-13-2023, 11:41 AM
thanks guys, its off to John on Monday
Old 01-14-2023, 02:59 PM
Just got my tach back from Jbell.
Tachometer looks great and looks like its working correctly now. Cant take it for a drive as I have the shifter all apart, but was able to start and rev the engine and its functioning correctly.
NSI had it for almost 2 months and was unable to repair it
Jbell had it for about 4 days and fixed it
Thanks to all here who referred me to Jbell
Now on to getting the sifter linkage all put back together.
Old 01-30-2023, 10:07 AM
1984 Tach Inop
Sent jbell959 a PM and hoping to hear back. same issue, was told these can have internals that get old and can stick.
Is the removal and re-install complex?
Appreciate any insight that can be provided.
Cost?? roughly?
thx
Old 08-30-2023, 01:07 PM
Still here
pmax's Avatar
Don't mind my technical inquiry but ...
what was the failure mode and the fix if known ?
Old 08-30-2023, 01:39 PM
pmax -- around 20 years ago, the tach on my '86 failed due to my not recognizing voltage spikes caused by a failing voltage regulator. Palo Alto speedometer fixed whatever in it was fried by the over voltage and it's been fine ever since
Old 08-30-2023, 01:59 PM
I understand (IIRC, old thread by Grady, RIP), that both the speedo and the tach were fitted with 15V electrolytic capacitors originally.
Not only do these not like being continuously supplied with voltage substantially above 15V, but these capacitors have a finite lifespan and can also simply fail from age (common reason old PCs and guitar amps stop working). Many repair places will replace these capacitors with one with a higher voltage rating, like 25V, instead...
The "classic" symptom of a voltage regulator dying is voltage spikes causing spiking tach readings. However, some VRs simply stop working altogether (and give 18V unregulated output) with no spikes. My tach never spiked - only clues were a measured steady 18V across the battery terminals at idle when I noticed a huge fuzz ball growing on the battery post....
Couple of years later when it failed entirely, turned out that the odd speedo behavior (needle jumping around and not reading constant speed) I'd noticed since was likely that being damaged from the VR going south - as a replacement gave rock-steady readings.
'77 S with '78 930 power and a few other things.
Old 08-31-2023, 12:21 PM
Older tachs (74? about there I think) require a higher-voltage signal than the later ones. You can adapt these with a tach adapter. Or wire the coil of a relay in-line with the TD pin - EMF generated as the pulse collapses gives a "fat" enough signal to drive the older instruments.
I believe John Bell fits a tach adapter board as standard.
Anything later (eg after ignition changed to CDI?) is pretty much interchangeable between any F/G body car, I think.
Another shout out for John Bell - tach and boost gauge both his work:
Old 08-31-2023, 12:48 PM
mine is a 1985 911
the issue is, when cold the tachometer does not move, sometimes stays lower than 500 RPM, just sits still. after driving for maybe 20 mins it starts working as it should. any ideas? thanks
Old 02-08-2024, 12:50 PM
