jmz jmz is online now
jmz's Avatar
Request for Help for someone who truly knows enough to be dangerous
OK, This is a quesiton from one of those guys who truly knows enough to be dangerous. I've done a number of engine drops and re-insalls and a couple of trans/engine seperations. Well, on this last one, it looks like I screwed up.
I dropped the engine to pull the tranny off to have it rebuilt. I recently reattached the two and installed them into the car. It seems that the clutch fork will not move.
Could this be a clutch alignment problem?
I had assumed that if you could attach the engine to the trans the fork had only one place to go, the right place! wrong or right?
I am really looking forward to getting the car put back together and moving on to the suspension mods.
Can anyone suggest what may have been done wrong?
Do I need to drop the engine and seperate again?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 06-19-2003, 07:40 AM
Somewhere in the Midwest
MotoSook's Avatar
The clutch fork has to ride on the throw out bearing. If it is not right, it is likely infront of (toward the front of car) bearing, againts the trans..or..well, it's not right!
Pull the motor and trans apart and get a helper to rotate the fork into position as you mate the two. It can be done with a "partial drop".
With a flashlight, you can see the fork and TOB as the two mate up.
Good luck.
Old 06-19-2003, 07:49 AM
addictionMS's Avatar
Souk is right, it is possible to mate the engine and trani with the fork in the wrong place, sounds like your problem.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 06-19-2003, 08:02 AM
jmz's Avatar
thanks, I haven't got to far re-installing so I think it may be easier to disconnect the CV'S and oil lines and drop the whole unit rather than a partial drop. What do you think?
Old 06-19-2003, 08:09 AM
MotoSook's Avatar
if getting the trans mount bolts in is easy on your car..go for what makes you happy, but those damn bolts are a PIA to line up..I almost stripped a part of one of my trans bolt hole once and had to run out to Sears for an appropriate tap to chase the threads!
Old 06-19-2003, 08:17 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Jim,
Here are my tribulations:
Correct way to mate motor and transmission???
Motor does not want to slide into transmission
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 06-19-2003, 10:12 AM
