81 911 SC -> 95 3.6 vram swap track / hot rod build.- help
Hey Everyone.
Over the Past few years I have gone from a stock 911 sc to a bit of a weekend hot rod / light DE car. We were able to do a full elephant racing suspension setup and loose around 300lbs, the car has been incredibly fun on the track and a total riot during the weekends and longer road trips (a few Porsche parades) the only issue was the strait line speed, the car is awesome in the corners, but ever strait we would get passed by the newer cars. a few months ago I was able to bite the bullet on a 95 vram engine with 39K miles. I wanted to make this thread to show some progress, but also get a bit of help with the engine swap. here are a few pictures and a few questions ![]() [URL=http://smg.photobucket.com/user/tred/media/1382842_10100513241437262_1885462291_n_zpshyfwrpx8 .jpg.html][IMG] ![]() [URL=http://smg.photobucket.com/user/tred/media/1379726_10100493997212842_553572200_n_zpsmzhm8ecp. jpg.html][IMG] ![]() ![]() ![]() and of course, the new engine ![]() to this
Your cars going to be an absolute blast. I actually thought these swaps wouldn't be done as much anymore due to the cost increases on those motors. Super jealous, keep us updated
\![]() all of this and more is in this thread
Where did you find your muffler?
Todd
'81 SC |
awesome build
(kg/lb) |
I assume that the motor is a US '96-98 w/ OBD2 and SAI
![]() That is a vent to the oil tank When I did mine I used a RoW '97 OBD1 motor w/o SAI here is what that area looks like on mine w/o SAI ![]()
Another oil tank vent, see above
Looks great, but I have a question. Why did you change the intake to a nonvram?
Creizai
Thanks, yeah the engines are far from cheap, in fact the engine cost more than the car was worth 5 years ago. I looked into building my 3.0 to 250rwhp or so and the 3.6 just came out better in nearly every way. Bill Verburg thank you for the info- ill trace the lines this weekend, they may be a bit different than stock as I'm not using everything, but I should be able to figure something out toddu the exhaust is a stock997 gt3rs exhaust I will have mated to s-car-go race headers, the goal is to have an electronic cut off to have two different exhaust paths= one street one track Bill Verburg this engine is a 95 with vram conversion. I like the idea of obd1 for its simplicity- thank you so much for the pictures! you are the man! so the two big lines vent to the oil tank? if so, do you know why? it seems like it would be more of a risk for oik to go into the intake if over filled vs a filter on the oil tank- or maybe I'm seeing this wrong. 0396 the engine was converted to v-ram, not removed. |
![]() ![]() Yes, overfilling is a no no!
RE^^^^
does the stock 81 oil tank have connectors for these? I don't remember taking any air lines off the oil tank= but I did remove the engine a while ago so my memory may not be spot on. thank you again for the help! |
![]() Here's what my '76 C3 w/ 993 looks like from below, '74 oil lines, B&B headers custom ordered w/ 964 heat inlet and 911 heat outlets, 964 heat crossover, Flowmaster muffler
beautiful paint on that engine
"IGNITION LEFT OF STEERING" Alex |
Cars Ruined My Life
My kind of build.
Bill Verbung, we can not pay you enough. You unconditionally share your information with everyone. Thank you Sir. |
I also did a 3.6 conversion on an 80SC.
Did the following for reliability and safety reasons: Mounted the coils on the left side engine compartment to reduce vibe Also placed a "Puke Tank" in the left rear wheel well for no oil fumes emissions into hot engine compartment . Upgrade of ALL the 35 yr old oil lines, fuel lines to optimally sized, SS jacketed AN type hoses with a stock 964 Porsche fuel filter. Modification of the throttle linkage to achieve WFOT was last item
1980 911 - Metzger 3.6L 2016 Cayman S |
Fastest Hunk of Junk
I'm excited this build is semi-local, hope to see the beast at some point in the future (though it may be an expensive meeting for me)!
-Brent |
By the way, you can nicely hide the vacuum reservoirs under the intake.
Im liking your exhaust plans, been tempted to do the same.
911-87 mit der 3.6 V-Ram und alles spaß |
