O2 sensors names
I replaced both O2 sensors on the passenger side and the upstream on the left side - located in the catalytic converter but still have a fault code P0130 bank 1 sensor 1 malfunction. Question is which O2 sensor is this. I have yet to replace the far right sensor… downstream I believe it is.
Old 01-29-2024, 01:13 PM
PCA Member since 1988
What year?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-29-2024, 10:46 PM
P0130 is the pre cat sensor on the left side.
Do you have access to a scan tool with a data stream?
Old 01-29-2024, 11:11 PM
