LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Dept store Quartermaster
lendaddy's Avatar
Dam*it, it's always something. Need advice on modifying oil line
Ahh yes, was there any doubt something would come up to slow my project? The oil line from the tstat to the crossover line is too long (remember my 930 is a little shoprter in the back than '78 and on) and is kinking. I have the correct part # but I am wondering if they just don't make the "shorter one" anymore? Can I cut the rubber line and put in a quality elbow with clamps? Can you hear the screaming in my head?
Cornpoppin' Pony Soldier
Old 06-19-2003, 07:14 AM
echrisconnor's Avatar
My quick two options:
1. Take the oil line out and bring it to a hydraulic shop. Have them shorten the soft line and re-swage the ends. Should cost you about $5. Don't try an elbow and don't use hose clamps.
2. Bend the hard oil line at the rear of the car further back giving the soft line more space to extend and straighten out (this is what I did).
'76 911 Carrera 3.0
Old 06-19-2003, 07:40 AM
Not Quite Banned
Thomas Owen's Avatar
Get the hydraulic shop to put a new end on the hose. You have done a great job with this so far - don't cut corners at the end. Also, make sure the hose will allow you to remove that lower valve cover when you need to do adjustments...
Thomas Owen
1972 911T
1972 911S
Old 06-19-2003, 07:45 AM
lendaddy's Avatar
Good ideas guys, I have a hydraulic hose maker two doors down! I will pull it at lunch today and bring it over there. Now I have to decide how much shorter I want it, this aught to be good
Old 06-19-2003, 07:47 AM
Irrationally exuberant
ChrisBennet's Avatar
Do hydraulic hose places normally have metric fitting on hand? Maybe for Japanese construction equipment?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-19-2003, 08:05 AM
lendaddy's Avatar
Good ? If they are just re-crimping I shouldn't need a fitting right? I would assume the crimp collars are common?.?
Old 06-19-2003, 08:13 AM
Senior Member
Doug Zielke's Avatar
I think you'll find the crimp collar is integral with the (metric) threaded fitting.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 06-19-2003, 08:18 AM
RETIRED
Joe Bob's Avatar
It's a recrimp job as the most....or they can take a piece out of the middle and do a repair....when Ingo rubbed his oil line that's how they did the repair.
BTW, did you try to reposition the T-STat? I had to when I did the 3.6 install....
2012 ML350 3.0 Turbo Diesel
Old 06-19-2003, 08:19 AM
lendaddy's Avatar
Mikez, Relocate the tstat? How would that work, aren't those all hard lines into the tstat?
Old 06-19-2003, 08:25 AM
RETIRED
Joe Bob's Avatar
Not relocate....reposition.....
Loosen all the tiedowns for the lines and adjust....you'd be surprised at the amount of slop there is......then tighten everything down.
Old 06-19-2003, 08:36 AM
lendaddy's Avatar
Worth a try, Thanks!
Old 06-19-2003, 08:39 AM
Is it common for the rubber oil line to rest on the exchager?
Warren & Ron, may you rest in Peace.
lendaddy's Avatar
It's actually not, the picture makes it look that way. It is however close, and that is a function of the hose being too long.
Old 06-19-2003, 08:45 AM
