TDC on crank pulley does not align to TDC mark on distributor - 3.2 Carrera
Continuing my project to strip my 3.2 engine down to a long block, I rotated the crank pulley to the TDC mark and noted that distributor is not quite to the TDC mark. It needs to rotate a few more degrees.
Is this normal? The engine was running very well before I started the tear down.
Is this bad?
Is the distributor installed 1 gear tooth off?
Should I remove the distributor and get it aligned dead on the marks?
Old 02-04-2024, 04:16 PM
It's fine, carry on.
206 637 4071
Old 02-04-2024, 04:27 PM
GG Allin's Avatar
Having recently reinstalled my own distributor, and getting lined up perfectly, I find myself questioning this now. Being off by one tooth on my own looked similar the picture above.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 02-04-2024, 06:40 PM
One tooth either way would make a lot more difference than that. Carrera distributor bodies don't turn to adjust timing like SCs and earlier. You plug it in and you get what's pictured. The mechanical advance adjusts the rotor tip a bit as the rpm changes to keep it in phase.
206 637 4071
Old 02-04-2024, 07:51 PM
Jeff Alton's Avatar
What John said, that is aligned......
Cheers
www.turn3autosport.com
Old 02-08-2024, 07:23 PM
