Hi, after much thought, I decide to change the cog myself on my 1986 911 odometer, as it had deterioated and didn’t record mileage. I labelled all the wires when I took the speedo out, and then plugged them in again after the cog change. The issue I have now, is that as soon as I turn the ignition on, the speedo shoots all the way around past the top speed and hits the odometer reset switch. If I turn the ignition off, then the Speedo arm returns to the 0 mark. I have no idea what I have done to upset my speedo, but it’s not happy with me. Any help/suggestions would be very much appreciated. I thought I was saving money by doing the odometer cog myself, after watching numerous YouTube clips… and now it looks like I may have to end up spending money to rectify the new problem.
Check your connections
On my 86, they are brown, green, white, red, left to right viewed from the front.
1986 3.2 to 3.4 conversion |
| Tags |
| speedometer issues , speedometer needle broken , speedometer sensor |
