Small fan-large fan
To make sure I order the right size amber shroud for my 79 SC case, I need to beware of the fan size. My understanding is that the typical fan size was 245mm and the two year small size was 225mm? My rough dimensions on my fan blade diameter is 9.5 inches which suggests 245mm+-. So I should be safe going with the std (larger size) engine shroud? Was the fan housing OD the same for both fan sizes, or were the external dimensions different also?
TIA Speedo |
all the finning length are the same with the exception of the early SCs, which should be ten mm shorter. The housing for the early SCs have considerably deeper pockets under the retaining band.
Bruce |
Fan shroud size
I should have been more specific...the shroud part number I researched for the 78-79 SCs is 930 106 005 00 which is referred to as the smaller 225mm fan/shroud combo.
The shroud for the 80 and later SCs is 930 106 006 00 which is the larger 245mm fan/shroud (which incidentally should be the same size fan/shroud combination as the early fan shrouds up through 77). I am not sure I have ever owned a small fan/shroud, but want to be sure that the amber shroud I order is the correct size for my fan/shroud combo. Some of the fiberglass shroud manufacturers offer two sizes. I am not sure it matters how deep the fan shroud is...or does it? I will check the part numbers listed on the fan/shroud tomorrow to see what I have, as it may not be an SC fan/shroud anyway, but maybe earlier. ![]() |
Canyon Runner
Here you go
fan/shroud sizes
Does this mean the outer diameter of the shroud is the same for both 226mm and 245mm fans?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Under the radar
Thanks Gordon!
So, today when placing the new housing back onto the engine, I noticed that the increased size of the housing is interfering with the crankshaft pulley. ![]() A few questions from this lovely, new development:
1979 911 SC |
