Combo Gauge Install
68 911T Targa that I bought in pieces. I didn't take it apart so sometimes I have questions on how it goes back together. The large 100m combo gauge doesn't have the posts and bracket(s) like the other 4 gauges. So I'm not exactly sure how it was installed. None of my gauges had the rubber seals...those had been removed at disassembly I suppose. Do I use the gasket that also doubles as the mount? PN 91164190200. It seems to have been used on gauges in 1970+ https://www.pelicanparts.com/More_Info/91164190200 |
I drilled and tapped two holes, then glued two long screws in and cut the heads off.
