For Lands SAKES! The pulley nut won't budge!
I'm using the Pelican pulley wrench, and the wrench on the nut ("lefty loosey" correct?), won't budge!!. And the pulley wrench looks like it may even be warping...What gives???
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Tight Nuts
Must have been tightened too much last time off.
Shouldn't be that hard to do. Use some penetrating oil, WD40 or one of the others suggested on this board, let it set a bit and then try again. Use a different wrench...perhaps a socket and a long rachet, or torque wrench. Good Luck!
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
The stock toolkit tools work extremely well!! Of course, I bet you don't have the stock tools.
I just sprayed some Super-Tech lubricant (like W-D I guess), and we'll see what happens, the way it's going, I may need another new pulley wrench!
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) Last edited by kstylianos; 06-13-2003 at 01:20 PM.. |
If you just want to replace the belt, drive it down to the local shop and have them 'zap' it loose for you. You can replace the belt in their lot.
Or just have them zap it loose, tighten it back up to specs, drive back home and do your repairs. BTW: the only way mine came off was with an impact wrench. I broke the pully hold down tool
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I have the same problem. Even though I used a good amount of PB Blaster on the theads, I managed to bend the heck out of my pulley wrench the first time I tried it. I think it bent because the prongs were too long... they acted as levers and the end of the wrench just kind of twisted. Last weekend, I was talking to the PO about the nut and he showed me his wrench and the prongs on it were much shorter... 20mm to be exact. I'm going to cut the prongs down to size and try it again.
Ken 1974 Porsche 914 2.0 "Babydoll" |
I don't want to replace the belt now necessarily, but I'd like to be able to remove it if ever needed in travel or what-not.
The outer part of the pulley itself (the part with the eight holes) seems to be sliding underneath the nut itself, so ironically it seems that it needs tightening?????...yet I cannot loosen it?????? ..And the super lub trick has failed so far.......
Still won't budge.......Off to another project....project 102.."How to bend your pulley wrench back to specs".....
According to my car's PO, "zapping" it may break the fan. That's why I haven't taken my impact wrench to it. Yet.
Due to some quirk in nature, torque gradually applied to 250 ft. lbs. does not have the effect as the same amount applied suddenly.
I vote for the impact gun. This method works equally well for front strut nuts, rear axle nuts and lug nuts (in general). Sherwood Lee http://members.rennlist.org/911pcars |
Irrationally exuberant
I know this will sound strang but an impact gun can be surprisingly gentle. It hits the fastener with a sharp impact like using a small/light hammer. It isn't the butcher's tool many people think it is. Like any tool you can abuse it. Heck, just because some people use oil filter wrenches to tighten oil filters, it doesn't make oil filter wrenches bad.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
John C 1988 911 Carrera coupe 2002 BMW 530 |
PB Blaster is magic stuff. Most auto parts houses sell it.
1984 Targa |
-Chris |
In the spirit of Talmudic debate, isn't it better to over rather than under-tighten an oil filter? You can always get it off with brute force latter, but if it falls off in flight, you may not notice the trail of oil beind you.
My pulley nut was so tight and at such an angle that the impact would not take it off. I ended up sticking one of the prongs on my forklift into the engine bay and using it to support the spanner wrench, then I put the breaker bar on the nut to finally get it to break loose. Actually bent the pulley before it came off.
Randy '87 911 Targa '17 Macan GTS |
"Apply light film of oil to seal on oil filter, install by hand, turning until seal makes contact. Finally, tighten further by approx. 1/2 turn." -Chris |
Ok so if you tighten oil filters by hand, where did this whole market for oil filter wrenches come from? Surely if you torque them down by hand, the torque required to remove them will be the same.
2004 VW R32 - B road bahnstormer 1992 Peugeot 205 - Tarmac rally weapon (well eventually...) Last edited by Langers; 06-14-2003 at 05:32 AM.. |
