How do you remove the Momo steering wheel hub?
I'm trying to get to the high beam switch but can't figure out how to remove the Momo hub. How do I remove it? Thanks for your help!
Site was glitchy and I didn't realize I posted triplicate post. Sorry. Mods please remove the two extra posts.
Put the steering wheel back on the hub and LOOSELY replace the 27 mm retaining nut (failing to replace the nut may result in you hitting yourself in the face).
Wiggle and pull the hub off the splines. Remove nut and finish removal.
So many rookie mistakes.
Where does this cable go?
