Best uniball choice for the rear trailing arm
Hi
I've done a nice rebuilt for the suspension set with a 3.0SC
RSR sway bar bilstein mill lac etc ...
I installed also Uniball for the rear trailing arms
I choose the one from Rebel racing.
after 15,000 miles one is doing noise ..... lateral play
purpose is not to complain about a brand ... it's competition parts.
As I should replace both ... and it's a little time consuming I would like to choose the best uniball solution for the rear trailing arm
I see
Elephant Racing solution
Tarret Solution
Rennline solution (I think it's Tarret rebranded)
what's the best solution in term of longevity ? (I do not ask 100,000 miles)
thanks for sharing your feedback
Old 02-21-2024, 08:47 AM
Navin Johnson
TimT's Avatar
You don't need to get new parts from Elephant or Rebel, you can press out the spherical bearing insert.. and replace it.. You may have to measure it to match a suitable replacement, or there may be a part number visible. The inserts are just help in with a circlip..
Spherical bearings
https://www.pegasusautoracing.com/spherical bearing
Pic from Rebel site showing the bearing the part number is out of focus or obscured
And yes replace both..
'69 911 GT-5
'75 914 GT-3
and others
Old 02-21-2024, 01:45 PM
Need to find the correct size to change just the spherical bearing
Seems price is close to the replacement part from on if the brand elephant or other …
Old 02-21-2024, 03:46 PM
shoooo32's Avatar
https://www.pegasusautoracing.com/group.asp?GroupID=SPHERICAL
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 02-22-2024, 09:54 AM
Old 02-23-2024, 09:41 AM
rennline fitted
no more noise ...
seems I have a lateral play with the washer before
we notice also for one arm the uniball insertion is easy (no need to press) to insert it
perhaps an issue here
I will see in a few miles if it's still ok
thanks again for your help
Old 03-13-2024, 06:55 AM
