bose213's Avatar
Speedometer doesn't work, but odometer works
Hi.
The Speedo on my 911sc 1979 doesn't work. However, the odometer works great. I checked the wiring, and it's correct. The sensor is working and reading all magnets in the transmission.
What could be a problem?
31b connector is giving 5volts, is it okay?
Thanks.
Arthur.
Owns a Porsche 911sc 1979 Sportomatic.
Old 02-22-2024, 03:44 AM
Matthew_VA's Avatar
refereshing this thread. working on another project but I measured 5.2V off the 31b terminal.
For the community, a question I have is, so the speedo measures the speed through a ground pulse with every magnetic pass (basically a square wave) and the faster the "pulses" occur the faster the speed is shown on the speedo, right?
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 07-10-2024, 08:25 AM
There's probably a loose connection inside - a cold solder joint. If you open it up and run a soldering iron over each point to refresh it, it might start working again.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 07-10-2024, 10:29 AM
